Revit crashing when I am writing some code in ComponentManager_UIElementActivate
nitinjambhale
nitinjambhale
I am trying to start the Revit's Transaction in
private void ComponentManager_UIElementActivated(object sender, Adwin.UIElementActivatedEventArgs e)
          Transaction transaction = new Transaction(doc, "Test"))
           transaction.Start("Test");
But, Revit is crashing when it hit the transaction.Start() method.
I am on Revit API 2020.
jeremytammik
Dear Nitin,
Welcome to Revit API programming!
To get started with the Revit API, I suggest that you first of all take a look at the getting started material and work through the step-by-step instructions provided by the DevTV and My First Revit Plugin video tutorials:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
That will explain all you need, including the answer to your question.
For a quick start, you can also check out the hello world examples in the developer guide:
http://help.autodesk.com/view/RVT/2018/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Introduction_G...
A slightly more complex answer to your question is this:
All calls to the Revit API require a valid Revit API context:
Such a context is not provided by the UIElementActivated.
Therefore, you cannot use the Revit API there at all, and consequently not start a transaction either.
Jeremy Tammik
Developer Technical Services
The Building Coder
