Revit crashes when trying to get dependent family
Hi team,
I instantiated a family symbol (a door) using the following code:
FamilyInstance instance = doc.Create.NewFamilyInstance(
	new XYZ(),
	familySymbol,
	doc.GetElement(familySymbol.LevelId) as Level,
	Autodesk.Revit.DB.Structure.StructuralType.UnknownFraming
However, the catch is this FamilySymbol (the door) is dependent on another FamilySymbol (a doorknob).
So when I try to hide the door:
view.HideElements(new List<ElementId> { instance.id });
The door is hidden, but the doorknob is left there.
How do I hide both the door and doorknob?
I tried to get the dependent element of the door, like so:
ElementFilter ef = new ElementClassFilter(typeof(FamilyInstance));
IList<ElementId> dependentElements = instance.GetDependentElements(ef);
foreach (ElementId id in dependentElements)
	Debug.WriteLine(doc.GetElement(id).Name);
but Revit just crashes unexpectedly., so no stack trace/ error message is available.
Important Note:
The doorSymbol and its doorknobSymbol is copied over from the original document and spawned in a different document.
// copy over the symbol to spawn into the new document
Family fam = uiapp.ActiveUIDocument.Document.EditFamily(doorSymbol.Family).LoadFamily(doc);
May I know how to resolve this issue? I need to hide both the door and its dependent family.
Attached is the revit family.
joshua.lumley
The first step is to stop revit from crashing by handling and recording errors. Use this code.
int eL = -1;
            try
//stick your code in here
            #region catch and finally
            catch (Exception ex)
                writeDebug("WindowLoaded, error line:" + eL +  Environment.NewLine + ex.Message + Environment.NewLine + ex.InnerException, true);
            finally
            #endregion
        public static void writeDebug(string x, bool AndShow)
            string path = (System.Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments) + "\\` aa Error messages");
            if (!System.IO.Directory.Exists(path)) System.IO.Directory.CreateDirectory(path);
            string FILE_NAME = (path + "\\" + DateTime.Now.ToString("yyyyMMddHHmmss") + ".txt");
            System.IO.File.Create(FILE_NAME).Dispose();
            System.IO.StreamWriter objWriter = new System.IO.StreamWriter(FILE_NAME, true);
            objWriter.WriteLine(x);
            objWriter.Close();
            if(AndShow)System.Diagnostics.Process.Start(FILE_NAME);
Hi @joshua.lumley ,
I have followed what you said, but Revit still crashes and I don't see any debug files created in the file path.
joshua.lumley
Make sure ALL the code is inside the try statement, not just the part you think is causing the crashing.
RPTHOMAS108
No issue with below, it also hides the door handle ok, feedback within code comments. Testing with 2021 not 2020.
My main comment is that you need to break some of the statements down into more parts so you can investigate with stepping where issues occur better.
public Result TObj131(Autodesk.Revit.UI.ExternalCommandData commandData, ref string message, Autodesk.Revit.DB.ElementSet elements)
			UIApplication UIApp = commandData.Application;
			if (UIApp.ActiveUIDocument == null)
				return Result.Cancelled;
			Document Doc = UIApp.ActiveUIDocument.Document;
			string FPath = "C:\\temp\\Steelcase%20PolyVision%20-%20Sans%20Light%20-%20Board (1).rfa";
			//Consider renaming above to take out %20 parts (parts associated with spaces)
			Document FDoc = UIApp.Application.OpenDocumentFile(FPath);
			//Not sure why not just load family directly into project from file instead of below?
			Family F = FDoc.LoadFamily(Doc);
			ElementId FS_ID = F.GetFamilySymbolIds().FirstOrDefault();
			FamilySymbol FS = Doc.GetElement(FS_ID) as FamilySymbol;
			//Best place to get a level is directly from the document not level property of FamilySymbol just inserted
			ElementClassFilter ECF_LV = new ElementClassFilter(typeof(Level));
			FilteredElementCollector FEC = new FilteredElementCollector(Doc);
			Level Ls = FEC.WherePasses(ECF_LV).Cast<Level>().OrderBy(x => x.Elevation).FirstOrDefault();
			if (ECF_LV == null)
				return Result.Succeeded;
			FamilyInstance Fi = null;
			using (Transaction tx = new Transaction(Doc, "New instance"))
				if (tx.Start() == TransactionStatus.Started)
					if (FS.IsActive == false)
						FS.Activate();
					//Furniture is not structural therefore use StructuralType.NonStructural
					Fi = Doc.Create.NewFamilyInstance(XYZ.Zero, FS, Ls, StructuralType.NonStructural);
					tx.Commit();
			if (Fi == null)
			ElementClassFilter ECF_FI = new ElementClassFilter(typeof(FamilyInstance));
			IList<ElementId> EIDs = Fi.GetDependentElements(ECF_FI);
			//Could use this for shared families within family instances
			ICollection<ElementId> Si = Fi.GetSubComponentIds();
			for (int i = 0; i <= EIDs.Count - 1; i++)
				Element El = Doc.GetElement(EIDs[i]);
				Debug.WriteLine(El.Name + " " + Convert.ToString(El.Id.IntegerValue));
				if (El.Name == "Toolbar - Collaborative")
					if (El.CanBeHidden(Doc.ActiveView))
						using (Transaction Tx = new Transaction(Doc, "Hide door knob"))
							if (Tx.Start() == TransactionStatus.Started)
								Doc.ActiveView.HideElements(new ElementId[] { EIDs[i] }.ToList());
								Tx.Commit();
Hi @RPTHOMAS108,
Thanks for such a detailed explanation, it solved my issue!
I had to use:
to get the level instead of:
Apparently that's what's causing the crash. Thanks 🙂
