Revit crash when call Export() function after call C# SaveFileDialog
winderbless
winderbless
hi everyone,
i meet a strange problem, thus
First, i call Document.Export() function export a view to dwg;
Secong, i call C# Class  SaveFileDialog want to select a path,
but when  SaveFileDialog.ShowDialog() called, Revit will Crash.
a necessary condition to show this problem is when command begin runing, change window focus to another window, like Windows Exploer.
my code is like this:
public class ExportCmd : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            Document doc = commandData.Application.ActiveUIDocument.Document;
            ICollection<Element> views = new FilteredElementCollector(doc).OfClass(typeof(ViewPlan)).ToElements();
            List<ElementId> lstPlanViews = new List<ElementId>();
            foreach (Element v in views)
                ViewPlan tv = (ViewPlan)v;
                if (tv.CanBePrinted)
                    lstPlanViews.Add(tv.Id);
                    break;
            DWGExportOptions m_dwgOptions = new DWGExportOptions
                FileVersion = ACADVersion.R2013,
            doc.Export(@"d:/aaa", "Teeee", lstPlanViews, m_dwgOptions);
            Microsoft.Win32.SaveFileDialog saveDlg = new Microsoft.Win32.SaveFileDialog();
            if (saveDlg.ShowDialog() == true)
            return Result.Succeeded;
This problem is shown in Revit 2015 to Revit 2018.
Did any one meeted this problem?
thx.
Check using 'try.....catch()' in your code.
You will get better idea about crash, when debugger goes into 'catch' section.
try
         //Execute function code
         //your code
catch(Exception ex)
        System.Windows.Forms.MessageBox.Show(ex.Message);
BIM.Frankliang
Dear Friend,
         First, the output folder must exist (API required)
         Second, I used to System.Windows.Forms.SaveFileDialog, you could try
         Wish it is helpful for you 🙂
Best Regards
Frank Liang
TJAD BIM Software Dev Lead
winderbless
Here is some more detail about this problem:
1. In Revit 2015 - Revit 2018, when this problem shown, Revit will crash immediately, and show this dialog, when click the button(the text in button means OK), revit will close and show Autodesk Error Report Dialog.
2. After I installed Revit 2018.0.3 Security Fix Updata, when this problem shown, Revit 2018 show more information:
after click the button OK, Revit work well, but when i close Revit will get this message:
(the chinese means "meet uncomfortab parameter", and the button means close.)
3. if I use Autodesk.Revit.UI.FileSaveDialog replace WinForm`s SaveFileDialog,  it worked well.
A necessary condition to show this problem is when command begin runing, change window focus to another window, like Windows Explorer. if did`t change window focus, this problem whould`t shown.
and i write a function to active Revit`s Window manual before i show FileSaveDialog. it worked in most times.
[System.Runtime.InteropServices.DllImport("user32.dll")]
[return: System.Runtime.InteropServices.MarshalAs(System.Runtime.InteropServices.UnmanagedType.Bool)] private static extern bool SetForegroundWindow(IntPtr hWnd);       private static bool ActivateWindow() {     System.Diagnostics.Process p = System.Diagnostics.Process.GetProcessesByName("Revit").FirstOrDefault();     IntPtr ptr = p.MainWindowHandle;     if (ptr != IntPtr.Zero)     {         SetForegroundWindow(ptr);         return true;     }     return false; }
so, i think this problem is interrelated Window Focus Change, maybe is a bug in Revit API Document.Export() function.
winderbless
thank your reply.
i tryed this, but it dit`t work,.
i think is because Revit has crash, so the program in catch did`t have chance run.
winderbless
thank your reply and
1. i created the output folder manual just for test.
2. at begining i truly used System.Windows.Forms.SaveFileDialog, i think problem in this dialog, so i change to Win32 dialog.
