Revit - Button in Ribbon outside screen error
chalJ22EL
chalJ22EL
Hi
I have this issue with one of the ribbons, one of the icons is jumping out of the screen:
This is not a general problem in my team with same plugins and screen settings:
our screen settings:
Any suggestions to fix this issue?
ricaun
Remove the NTI plugin from the Modify tab.
Plugins are not supposed to put RibbonPanel in the Modify tab.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
chalJ22EL
I do agree, its not suppose to be there from the developers side. But we are 400 people running this plugin, and i haven't seen the issue for anyone else. So i wonder what dose trigger this error.
RPTHOMAS108
It doesn't stack or scroll so it is always going to go off the screen (even the built-in buttons) putting extra things there just pushes it off the end quicker.
Perhaps other people don't report the issue because they are using alternatives such as quick access or keyboard shortcuts. Perhaps they run it but don't use the other things they are missing with it.
The other issue with it being on modify is you can't drag the panel out into it's own window.
