REVIT API
REVIT API
pelin_sarac
REVIT API
pelin_sarac
Hallo zusammen,
I have created a Ribbon button. When I the second Ribbon button, I saw this failure.
Could you pls help me ? attachment foto
Thank you
jeremy_tammik
The requested and missing PDB file is a so-called program database used for debugging:
https://en.wikipedia.org/wiki/Program_database
It is not needed by your add-in, only for debugging AddInManagerUI.dll, which you should not be doing.
I have never seen or heard of this message before, so I would assume that you are doing something unusual.
I would suggest restarting from scratch with a clean slate, tabula rasa, and following a step-by-step tutorial exactly; the message should not appear.
MarryTookMyCoffe
that look like you try to debug your application, and try enter a dll not loaded in maping. There is a option in visual studio to not go into a dll that are not yours, I thing in bottom of this prompt is a hint how to turn it off.
do not worry it only gonna take Autodesk 5 years to fix bug
