Revit API / WIndows Forms / IExternal Commands
Has anyone has success implementing forms into an external command to be read and implemented into a ribbon application? I have the ribbon features, but am having issues between the external command and windows forms. Please see the code below... Any help would be greatly appreciated!!! Thank you.
using Autodesk.Revit.UI;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.DB.Architecture;
using System.IO;
using System.Windows.Media.Imaging;
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
namespace Project_Button
public partial class Form1 : Form
public Form1()
InitializeComponent();
private void saveFD_FileOk(object sender, CancelEventArgs e)
private void openFD_FileOk(object sender, CancelEventArgs e)
private void button1_Click(object sender, EventArgs e)
saveFD.InitialDirectory = ("C:");
saveFD.Title = "Save Project Template";
saveFD.Filter = "Text Files(*.txt)|*.txt";
saveFD.Filter = "Text Files|*.txt|Word Files|*.doc";
saveFD.ShowDialog();
private void button3_Click(object sender, EventArgs e)
openFD.InitialDirectory = ("C:");
openFD.Title = "Open Project Template";
openFD.Filter = "Text Files(*.txt)|*.txt";
openFD.Filter = "Text Files|*.txt|Word Files|*.doc";
openFD.ShowDialog();
When I tried adding the external command lines as follows, my entire form became corrupt...
[Transaction(TransactionMode.Automatic)]
[Regeneration(RegenerationOption.Manual)]
public class ProjectButton : IExternalCommand
public Result Execute(
Autodesk.Revit.UI.ExternalCommandData commandData,
ref string message,
Autodesk.Revit.DB.ElementSet elements)
THANKS AGAIN GUYS!!!
