See below email sent to the ReCap API group. I am sure you folks have a lot more than 2 cents to add.
TIA,
-Ramon F. Herrera
JFK Numbers
[email protected]
Hello:
My one-person, not-for-profit organization was the fortunate recipient of a donation, the point cloud data collected for this 2013 program:
PBS NOVA Cold Case JFK: Laser Scanning and Models
The data resides here:
Dealey Plaza Laser Scan Data from PBS Nova
I have already produced a lot of value added, such as:
Rendered TSBD from PBS Point Cloud
My question is about the next project, which -frankly- should be historic. See attached mock up images below.
What I want to develop is a very easy, web based tool that allows any user to measure any desired distances, angles, colinearity of 3-4 points, etc.
I am working with the author of this:
Motorcade 1963 by Mark Tyler
who needs to convert his 2D work to 3D.
I am ready to hire an expert to implement the first step: extract information (perhaps colored triangles?) from either:
(a) My point cloud file (sounds like a lot of work)
(b) The Revit model that I have, already extracted from that point cloud:
Revit Model from PBS Point Cloud Data
Questions:
(1) Which of the two mentioned APIs is most appropriate for this task?
(2) It seems to me that the Revit API is commercial while the ReCap API is Open Source (my kind of price)
I have the academic versions of much Autodesk software (thanks again!!!).
TIA,
-Ramon F. Herrera
JFK Numbers
This should further clarify:
Some fellow asked: "Ramon, I am interested to check this pet theory of mine. I wonder whether the real fatal shot is not seen in the Z-film because Kennedy was lying on the limo seat at the time, injured. The fatal bullet was actually shot from the southwest window, opposite the sniper's nest. Is there a line of sight at the precise time?"
"Bob: Make a generous contribution, and yours will be the first theory to be tested".
He offered five bucks.
When the producers of the PBS Nova documentary donated the 36,146,767 3D, RGB colored measurements, doctor Randy Robertson was impatient. He asked me to find somebody in Dallas who would take the 4-5 measurements that he needs. Perhaps they could be extracted right away from my raw data? I contacted my/your/our benefactor, Mike McCormick "can you correspond directly with doctor Robertson?". He'd rather not, preferred to keep it between enginerds. I explained to the Notable Doctor that the issue is not that simple, that measurements had to be synchronized with the Z-film and other images. There would be ranges, some +/- numbers.
GUI Tool Number One: The Robertson Measurement Tool. See preliminary prototypes attached below.
[The trajectory shown comes from another building, which will be measured at laser precision]
Users will be able to measure anything with the accuracy that only laser can provide: not only distances and angles but the Philosopher's Stone:
"How close are these 3-4 points to colinearity?" (The Single/Magic Bullet Theory, SBT/MBT).
