Revit API view template or scope box
I'm trying to apply a view template or scope box to views that I have created through the api coding. I have googled and have not found a way to apply a predefined scope box or view template to the view. Can anyone help?
You can ask a view for it's viewtemplate ID by
doc.ActiveView.ViewTemplateId
You can also set an ViewtemplateId (it's just a parameter).
For scopeboxes have a look at Jeremy's blog :
http://thebuildingcoder.typepad.com/blog/2012/08/set-view-section-box-to-match-scope-box.html
maybe this will help you further. Good luck,
Here is how I do it...
Set ViewTemplate if you know its name and/or Id
viewTempName = "My View Template";
View viewTemp = (from v in new FilteredElementCollector(doc).OfClass(typeof(View)).Cast<View>()
			    where v.IsTemplate == true && v.Name == viewTempName select v).First();
view.ViewTemplateId = viewTemp.Id;
To set a View's scope box, do it in the view's parameter VIEWER_VOLUME_OF_INTEREST_CROP
view.get_Parameter(BuiltInParameter.VIEWER_VOLUME_OF_INTEREST_CROP).Set(scopebox.Id);
sujeev
Hi
I am trying to apply a scope box to a view. I got the scope box using fileteredelementcollector. But I am not getting the "get_parameter" code. I am creating the macro using sharp develop in the manage tab. Am i missing something? I am new to revit api. Could you please help on this. I am using revit 2015.
Regards
Sujeev
