Revit API to edit Model Line Weights for a given scale
If you go to Manage tab, Additional Settings and select Line Weights you are presented with a dialog that has three tabs: Model Line Weights and two other which are out of my scope.
The question is:
Is there a way to edit a given line weight for a given view scale in the table? For example I'd like to set the line weight 5, for scale 1:100 to 2.8 mm, rather than 2.5mm.
Thanks.
Of course I meant through the Revit API.
I'm facing to the same issue.
Did somebody has a solution for this ?
Thanks in advance
maisoui
Same here, and I'd like to retrieve these values too.
Lack of the API ?
Regards
Jonathan
