Revit Api open and edit drawing autocad 2015
rodrigohbm
rodrigohbm
hola amigos
hay forma de abrir y editar dibujo de autocad desde revit:
tengo un proceso de exportacion a dwg desarrollado para revit, la idea es que luego de exportacion se edite el dibujo en autocad pro medio de codigo.
tengo las referecion de :
Autodesk.AutoCAD.Interop
Autodesk.AutoCAD.Interop.Common
Imports System.Runtime.InteropServices
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
CODIGO DEL PROCESO EXPORTACION A DWG EN REVIT.
A CONTINUACION PROCESO AUTOCAD
Dim AcadApp As Autodesk.AutoCAD.Interop.AcadApplication
Dim acaddoc As Autodesk.AutoCAD.Interop.AcadDocument
AcadApp = GetObject(, "Autocad.Application")
acaddoc = AcadApp.ActiveDocument
Dim dibujo As String = ( rutadir & nomarchivo )
acaddoc.Open( dibujo , False )
saludos.
Revitalizer
Dear rodrigohbm,
I think there a lots of people who want to help you but who don't understand Spain.
Sorry,
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
rodrigohbm
ok....Thanks!!
I have an application that opends a DWG,
but it simply uses:
                    System.Diagnostics.Process.Start(fullfp);
where fullpath = your DWG path
you need to have Autocad set as your default program to open DWG, but i would see no reason any Draughtsman would not...
Revitalizer
Hi Rodrigohbm,
and as you can see in my posting, it is not even necessary to use correct grammar to be understood, anyway.
Best regards,
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
rodrigohbm
ok....gracias
me resulto con:
dim AcadApp As Autodesk.AutoCAD.Interop.AcadApplication
dim acaddoc As Autodesk.AutoCAD.Interop.AcadDocument
Dim dwgName As String = rutadir & nomarchivo
AcadApp = GetObject(, "AUTOCAD.APPLICATION")
acaddoc = AcadApp.activeDocument
acaddoc.Application.Documents.Open(dwgName)
BKSpurgeon
hi thank you for your answer.
is there a way to do this without using interop? (i.e. I want to open an AutoCAD drawing, read it and extract some geometry, and then build Revit objects using that geometry).
will post code once i grok this.
any advice much appreciated.
