Revit API help with 2 sequential transactions
Currently, I made a tool to rename view numbers (“Detail Number”) on a sheet based on their location on the sheet. Where this is breaking is the transactions. Im trying to do two transactions sequentially in Revit Python Shell. I also did this originally in dynamo, and that had a similar fail , so I know its something to do with transactions. Transaction #1: Add a suffix (“-x”) to each detail number to ensure the new numbers won’t conflict (1 will be 1-x, 4 will be 4-x, etc) Transaction #2: Change detail numbers with calculated new number based on viewport location (1-x will be 3, 4-x will be 2, etc) Better visual explanation here: https://www.docdroid.net/EP1K9Di/161115-viewport-diagram-.pdf.html Attached is the python file, but essentially what im trying to do is: # <---- Make unique numbers t = Transaction(doc, 'Rename Detail Numbers') t.Start() for i, viewport in enumerate(viewports): setParam(viewport, "Detail Number",getParam(viewport,"Detail Number")+"x") t.Commit() # <---- Do the thang t2 = Transaction(doc, 'Rename Detail Numbers') t2.Start() for i, viewport in enumerate(viewports): setParam(viewport, "Detail Number",detailViewNumberData[i]) t2.Commit() Attached is py file
jeremytammik
dear chris,
please research this topic in depth and give it a nice deep ponder:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.33
the behaviour you describe indicates (well, hints at, very subtly) a need for regeneration.
cheers,
jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
matthew_taylor
Hi Chris,
To follow up on Jeremy's very insightful suggestion, check out transactionGroups and assimilate.
Cheers,
-Matt
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
jeremytammik
Thank you Matt, fully concur.
I added more background info in my answer to the same question on StackOverflow:
http://stackoverflow.com/questions/40728351/2-sequential-transactions-setting-detail-number-revit-ap...
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
jeremytammik
More was said on this issue in the StackOverflow thread, plus a completely different underlying problem was unearthed.
I summarised the entire discussion on The Building Coder:
http://thebuildingcoder.typepad.com/blog/2016/12/need-for-regen-and-parameter-display-name-confusion...
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
