Revit API for MVC web BIM application
Hi All,
I am new to the Revit API and started my journey with following blog: - http://thebuildingcoder.typepad.com/blog/2013/04/getting-started-with-the-revit-api.html. But all of the tutorials mentioned in the blog talk about creating macro and add-ins in existing Revit desktop application which comes with the Autodesk SDK. I did not find any detail regarding developing an independent (desktop/web) application using Revit API.
The idea is to create a web based BIM application using MVC and Revit API.
Does it support MVC and web platform?
If yes, then please guide me to some tutorial f links where I can find detail about building a BIM application using Revit API from scratch (not extending the Revit app provided by autodesk along with the SDK)?
Gracias
Raimundo
jeremytammik
Dear Raimundo,
Your impression is perfectly correct.
The Revit API supports the implementation of Revit add-ins and nothing else.
The Revit API is completely event driven. Your add-in can register with Revit, and Revit will drive it by raising events.
The add-in functionality is implemented in the event handlers, and nowhere else.
There is no support for a stand-alone application to drive Revit on its own.
The closest you can get is to implement a Revit add-in which implements a so-called external event, and then drive the external event from you own stand-alone application:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.28
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
poods1979
Community Visitor
Community Visitor
keep it up
