Revit API Developer Job
tim-bot
Message 1 of 1
tim-bot
I know this isn't directly related to the api, but the company I currently work for is looking for someone to replace me when I leave (got another opportunity in another field). currently our code base is in autocad and fabrication cadmep, but with the industry moving into revit, they're in need of someone to take over this transition and to translate much of the current code base into revit, as well as develop additional tools as needed to support a team of about 50 designers. it's the MEP industry, and there's definitely money to be made. RK is pretty much the best company I've ever worked for btw, just personal goals have sent me in a different direction.
i'm not entirely certain where to point them to find someone like this, I was hoping there was someone on here that may have some helpful knowledge about good places to direct them. or even better, if there was someone on here that may be interested, that would be even better.
if you're curious, check out the company careers page here: http://rkmi.com/careers/
if you can direct me in any way, please let me know, i'm sure they would be greatly appreciative. thanks!
Replies (0)
