Revit API code
Revit API code
tuanlongwf
Observer Observer
Revit API code
tuanlongwf
Observer
Observer
Hi, I create a project in visual studio code with revitapi, my client request that when I start/debug the project, Revit start and in Revit, I export to DWG for cad, the dimension's layers and names in cad must be the same in revit but I try everything yet cad doesn't read it, the layer table doesn't contain 4 dims that exist in revit, I need help about this, here is my code:
Mohamed_Arshad
Hi @tuanlongwf
Do you want to export the DWG with CAD Layer details from Revit API Code ? Is my understanding was correct ?
Mohamed Arshad K
Software Developer (CAD & BIM)
essam-salah
@Mohamed_Arshad wrote:
Hi @tuanlongwf
I think yes, do you have any experience with exporting from RVT to ACAD with keeping the layers?
tuanlongwf
Observer
Observer
I want to export the name of all dimensions to cad layer's table but no matter I try, it's still doesn't work. Their name still appear in dim style but in layer's table, their name replaced by default name from cad
ctm_mka
looking at your images, it looks like you are modifying the export setup, have you manually verified that those changes are applied after your programs completes?
tuanlongwf
Observer
Observer
yes, it transfer information of dims to dim style is success but the layer table doesn't change automatically, I have to change it manually
