Revit API - Change Text color in excel
Hisham_Odish
Hisham_Odish
Hi All,
I’m exporting schedules to excel and then I want to compare the value of 2 cells. If they are not equal then change the font to red. I’m able to format the font to bold, but don’t know how to change the color.
thanks for any help.
            xlRange = xlWorkSheet.get_Range("B4");
              xlRange2 = xlWorkSheet.get_Range("J4");
            if (xlRange.Value.ToString() != xlRange2.Value.ToString())
                xlRange = xlWorkSheet.get_Range("J4");
                xlRange.Font.Bold = true;
                xlRange.Font.Color = "Red";
josh.roth.MEI
Hi @Hisham_Odish ,
I think the problem lies with the value you are trying to assign to the font color. For your last line, try this instead:
xlRange.Font.ColorIndex = 3;
Sean_Page
Excel.Range rng2 = this.Application.get_Range("A1");
rng2.Font.Color = System.Drawing.ColorTranslator.ToOle(System.Drawing.Color.Red);
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
Hisham_Odish
hi @ jrothMEI, @ spage
thanks for your responses.
i tried your solution but didn't work. however when plugged in this value and it worked "0,0,255". also noticed the numbers should be right to left rather left to right. when using other coding, i usually type "255,0,0" for red color. but in this case i had to reverse the order of number to "0,0,255" to get color red.
thanks 🙂
