Revit API Assembly members validation
h.nijboerWAJKH
h.nijboerWAJKH
I encountered some strange behavior when adding elements to an assembly.
In Revit when I try to add an element to an existing Assembly which has Phase 'Created', and the element which I try to add has a different Phase I get a message:
Selected Element(s) cannot be added to the assembly. Elements must have the same phases as the assembly to be included in the assembly.
However when I am updating the same AssemblyInstance with new members using AddMemberIds method on the AssemblyInstance it works:
assemblyInstance.AddMemberIds(elementIdsToAddToAssembly);
When I am selecting the elements in the UI I see different phases for elements in the same assembly.
This shouldn't be possible I think?
Greetz,
jeremytammik
That sounds as if it should not be possible, indeed.
Please submit a minimal reproducible case that we can share with the development team for analysis and possible rectification:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Jeremy Tammik
Developer Technical Services
The Building Coder
h.nijboerWAJKH
Here you have my Revit test file with some specific test code for the attached Revit file..
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            var document = commandData.Application.ActiveUIDocument.Document;
            // Assembly instance with CreatedPhase: Phase 1
            var assemblyInstance = (AssemblyInstance)document.GetElement(new ElementId(296092));
            using (var transaction = new Transaction(document))
                transaction.Start("Combine walls");
                // Wall with CreatedPhase: Phase 2
                assemblyInstance.AddMemberIds(new[] { new ElementId((296124)) });
                transaction.Commit();
            return Result.Succeeded;
