Revit API and CI/CD
Revit API and CI/CD
lee6800
Revit API and CI/CD
lee6800
I have searched the forum and used google to try and find some instructions / tutorials on how to implement CI/CD on GitHub or GitLab.
I have been looking at the wonderful templates created by Nice3Point and like to understand how they work. Even a flow chart of what happens once you commit a change which triggers an action on github to create a new release(increasing "Version" Value in 'Build.Build.Configuration.cs' in Nice3Point template)
Also what is the best pipeline to use for this purpose.
Thanks for your help in advance
BKSpurgeon
CI / CD is relatively simple - checkout github actions:
https://docs.github.com/en/actions
lee6800
Than you very much for your reply
while reading various post here, been keep seeing "Azure" mentioned. where does this comes into the equation? Am I correct to assume it is used run to test the code?
Thanks again for your help
BKSpurgeon
Azure would have their own CI / CD product. I have not used Azure for that service. But I imagine they all kinda do similar things. CircleCi is another service provider that is popular in this space.
But I have used Github for web apps and other library code bases. For example, with Github:
  1. you add tests to your code base.
  2. you can set up a workflow like this: every time someone makes a pull request to the master branch - make sure all the tests pass. and if they don't: highlight it, and (possibly):
  3. prevent them from being merged.
You could have a similar set up, such that all tests must pass before deploying.
You could even have a "staging" environment.
I would say that an easy way to experiment with with github.
But if you want to run tests in a revit environment via a CI pipeline - then I cannot answer that question.
lee6800
Thank you very much for your help
