Revit Addin - Vault Connection
connor.ferguson
Message 1 of 9
connor.ferguson
We have a Revit addin that connects to Vault. Currently this is done by our own command that gets the user to login to Vault but it would be better if from our addin we could get the existing Vault Connection used by the standard Revit Vault addin. Is this possible? It can be done with Inventor but can't find a way with Revit.
Replies (8)
Message 2 of 9
jeremytammik
I am not aware of any such possibility. However, i have asked the Revit development team for you and will let you know what I find out.
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 9
connor.ferguson
Hi Jeremy, Any update on this?
Message 4 of 9
jeremytammik
Dear Connor, thank you for the prompt. Sorry, no reply from them yet. I'm retrying in a different and hopefully more appropriate internal slack channel... stay tuned...
Jeremy Tammik
The Building Coder
Message 5 of 9
O Caminho que você se refere é por .NET ? Atualmente.
Message 6 of 9
jeremytammik
Yes, the Revit API is purely .NET.
Jeremy Tammik
The Building Coder
Message 7 of 9
Take a look at the documentation in Autodesk.Datamanagement.Client.FrameWork.Vault.Library.ConnectionManager. There is a method called "GetExistingConnection". You should be able to use this to retrieve the existing Vault connection.
Message 8 of 9
cristian.barzaghi
this is valid if you are into a Vault add-in.
the question is: is possible to access Vault connection from a Revit add-in?
Inventor expose this by the Connectivity.InventorAddin.EdmAddin dll present in :\Program Files\Autodesk\Inventor 2022\Bin\: there is an equivalent for Revit?
Message 9 of 9
connor.ferguson
Hi Christian, i wasn't able to find an equivalent so i added the ability to log in to Vault through my revit addin, independant of the Vault Ribbon
