Revit addin Identity Problem during debugging unsigned addi
info4UZZZ
Observer Observer
info4UZZZ
Observer
Observer
Hi all
I'm facing a tedious problem.
During my addin development cycle normally I point my manifest file to the bin/x64/Debug/addin_to_debug.dll. Start debugging from VIsualStudio, Revit open, say that addin is not signed, I press load anyway and all is good.
Recently with both Revit 2022 and 2023 I'm incapable to proceed any further, the addin isn't loaded and all I got is this message.
I try to put addin both using a bundle inside ApplicationPlugins and in %AppData%/Autodesk/Revit/Addins/2023 but nothing change. All I got is an API Error inside the journal (see the attached file error for Superconsulting).
Uninstall Revit, delete all folders&regkey, reinstall Revit doesn't have any effect.
Any suggestion is more than welcome.
I would like to understand how is possible to investigate further to understand and solve this problem.
Paolo
jeremy_tammik
In your journal file, I see:
'C 29-Oct-2023 21:22:43.285;   0:< start up warnings for AddIns
' 0:< ::48:: Delta VM: Avail 134178426 MB, Used +1 -> 512 MB; RAM: Avail -12 -> 17771 MB, Used +0 -> 588 MB
' 0:< GUI Resource Usage GDI: Avail 9808, Used 192, User: Used 175
' 0:< TaskDialog "Revit cannot run the external application "CubintoForRevit". Contact the provider for assistance.  Information they provided to Revit about their identity: Cubinto, www.cubinto.com."
'Id : TaskDialog_External_Tools_External_Tool_Failure
'CommonButtons : Close
'DefaultButton : Close
  'C 29-Oct-2023 21:22:56.469;   0:< Notify Active View.
' 0:< ::48:: Delta VM: Avail +0 -> 134178427 MB, Used +2 -> 514 MB; RAM: Avail +12 -> 17784 MB, Used +5 -> 593 MB, Peak +1 -> 594 MB
' 0:< GUI Resource Usage GDI: Avail 9803, Used 197, User: Used 176
' 0:< TaskDialog "Revit cannot run the external application "Alessandria". Contact the provider for assistance.  Information they provided to Revit about their identity: Superconsulting."
What is CubintoForRevit?
info4UZZZ
Observer
Observer
It's another addin.
I was doing some testing. Anyway I attached the journal after CubintoForRevit was uninstalled.
Strange thing, CubintoForRevit has a couple of ShowMessage inside of StartUp, they works correctly but also this plugin was blocked in the end. I was also been able to connect with debugger in this case.
I ended up here: RevitManagedAppStartupAgency.cs
Can you suggest a simple RevitAddin, a sample, to use for testing?
P
jeremy_tammik
Yes, sure. Try making a minimal skeleton add-in yourself from scratch, e.g., following the official hello world sample from the developers guide:
It makes no difference what language you use, .NET and the Revit API are language agnostic, they just care about the IL code you pass in.
info4UZZZ
Observer
Observer
Thanks, I will try during this morning
