Revit Add-In
Revit Add-In
jesus_alfredo_alvino
Alumni Alumni
Revit Add-In
Hi everyone,
I have some inquiries about Add-Ins for Revit so I hope you can help me:
  1. Do we have a web where are listed all the Revit add ins ? , like a catalog so we can find more info about them.
  2. All the Add-Ins are visual options inside Revit ?
  3. It's supposed all the add-Ins should be displayed in the Add-Ins ribbon tab ?
  4. What are the first steps to create a new add-in for Revit ?
  5. Is there any compliance / policy to bear in mind about the creation of an Add-In ?
  6. Does Dynamo Player is considered as an Add-in ?
Thanks for your valuable answers in advanced.
jeremy_tammik
Actually, I think the most effective way to answer these in full and fully comprehend the answers would be to work through the getting started tutorials yourself. That would explain most of the questions:
Still, here are some quick first takes on them anyway:
Well, there is the Autodesk Revit AppStore. However, you are perfectly free to implement your own add-in and NOT register it in the AppStore, so the AppStore is by no means a complete list. So, the answer is definitely NO if you insist on the term 'all'.
No, you can implement a Revit add-in that presents no UI at all and just reacts fully automatically to certain events. Most add-ins do implement a UI, though.
No. That is completely up to the add-in vendor.
Work through the getting started material listed above.
No. Just do not corrupt your client's BIM.
I don't now. Who cares?
Thank you @jeremy_tammik !
