Revit Add-in Error: Wrong Full Class Name
minusung_work
Observer Observer
minusung_work
Observer
Observer
Hello Revit community,
I am trying to develop an add-in and I'm getting a mysterious Wrong Full Class Name error. My class implements the IExternalCommand interface, and the add-in seemingly has the correct path to the dll. I have tried different locations as well, but I keep getting this error:
Here is my class
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
namespace HelloWorld
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    public class Class1 : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            TaskDialog.Show("Revit", "Hello World");
            return Autodesk.Revit.UI.Result.Succeeded;
Build output:
1>HelloWorld -> C:\Sample\Debug\net8.0\HelloWorld.dll
1>Done building project "HelloWorld.csproj".
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
========== Build completed at 2:39 PM and took 00.489 seconds ==========
And the add-in file:
<?xml version="1.0" encoding="utf-8" standalone="no"?>
<RevitAddIns>
        <AddIn Type="Command">
                <Assembly>C:\Sample\Debug\net8.0\HelloWorld.dll</Assembly>
                <AddInId>239BD853-36E4-461f-9171-C5ACEDA4E721</AddInId>
                <FullClassName>HelloWorld.Class1</FullClassName>
                <Text>HelloWorld</Text>
                <VendorId>NAME</VendorId>
                <VendorDescription>Your Company Information</VendorDescription>
        </AddIn>
</RevitAddIns>
I can see my HelloWorld add-in under [Add-Ins > External Tools] but I get the Wrong Full Class Name error when I execute it.
Any help will be appreciated. Thanks.
jeremy_tammik
The files that you show in your query all look OK to me. Therefore, I suspect that there is something in your system that you are not showing, and may not be aware of. For instance, a duplicate DLL hanging around somewhere and confusing things. I suggest that you search your system globally for obsolete testing DLLs. Good luck!
jeremy_tammik
What release of Revit are you working with? None of the released versions of the Revit API support .NET 8. So far, the highest suppoerted version is .NET 4.8. Please check the development requirements in the developer guide:
ricaun
Probably@minusung_work is using the Revit 2025 reference which is NET 8.0. The last January Preview Release was updated from NET 7.0 to NET 8.0.
By the way, .NET Core Migration Webinar gonna happen soon.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
minusung_work
Observer
Observer
Right on. I was using Revit 2024 and .NET Framework 8 which was indeed the issue. It is working with .NET 4.8. Thanks!
jeremy_tammik
... watch out! No such thing as Revit 2025 exists, and the preview release is under NDA. Please join the feedback forum in order to discuss all aspects of the preview release in a protected environment 🙂
