Revit 2022 - Unable to Use
vcio
vcio
The installation of Revit 2022 has been successfully completed. However, the Command Prompt (black screen) continues to appear unexpectedly whenever Revit is open. Kindly see attached file for your reference.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @vcio ,
Does this issue occur only when using the Revit API, or does it also occur in Revit itself when the API is not involved? To me, it doesn’t look like an API issue, but rather a Revit product issue.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you should not expect answers here to questions related to product usage or end-user support.
Instead, you should try one of the non-API Revit product support discussion forums:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The members there are much better equipped to answer your question than we are.
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
