Revit 2022 - Graphics issues with Intel Iris Xe Graphics
tobias.henningL7AGA
tobias.henningL7AGA
I'm using the current Intel i5-1135G7 with the integrated Intel Iris Xe GPU for Revit. Their seems to be some graphical issues for instance when hovering over objects they get highlighted but everything gets higlighted until I zoom or shift the angle. Also when moving an object this happens:
I have already tried different drivers. Disabeling the hardware enhancement option is not an option for bigger projects. Is there a solution to this or can this be fixed?
jeremy_tammik
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
So, you cannot expect an answer to a question such as yours relating to system requirements, installation, product setup, optimisation, usage or other end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to address this topic than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
