Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
REVIT 2022 crashes after an external function call for a WPF window class
4 REPLIES 4
jerome.leignadier
358 Views, 4 Replies
Hi
I try to pass info from a cliquodrome to a function handling REVIT objects (so having to be outside the WPF class)
The WFP window work fine, if I test some function inside the class, it work well to but when I call external def ...
With a basic class, no problem but with WPF ... it’s stuck 😞
here is my code :
test.xaml
<Window xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
		xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
		Title="MainWindow" Height="550" Width="1000" Opacity="0.8">
	<Grid>
		<CheckBox Content="Génie Civil" x:Name="Lot10" IsChecked="True" HorizontalAlignment="Left" Height="16" Margin="8,10,0,0" VerticalAlignment="Top" Width="100" />
			<CheckBox Content="10" x:Name="ChkBox10" IsChecked="True" HorizontalAlignment="Left" Height="16" Margin="16,30,0,0" VerticalAlignment="Top" Width="50" />
			<CheckBox Content="11" x:Name="ChkBox11" IsChecked="True" HorizontalAlignment="Left" Height="16" Margin="16,50,0,0" VerticalAlignment="Top" Width="50" />
			<CheckBox Content="12" x:Name="ChkBox12" IsChecked="True" HorizontalAlignment="Left" Height="16" Margin="16,70,0,0" VerticalAlignment="Top" Width="50" />
			<CheckBox Content="13" x:Name="ChkBox13" IsChecked="True" HorizontalAlignment="Left" Height="16" Margin="16,90,0,0" VerticalAlignment="Top" Width="50" />
			<CheckBox Content="14" x:Name="ChkBox14" IsChecked="True" HorizontalAlignment="Left" Height="16" Margin="16,110,0,0" VerticalAlignment="Top" Width="50" />
		<Button
			Content="GO"
			x:Name="BOUTTON" Click="Button_GO"
			HorizontalAlignment="Left" Margin="250,450,0,0" VerticalAlignment="Top" Width="150"
	</Grid>
</Window>
and script.py (on pyRevit context) :
# -*- coding: utf-8 -*-
from pyrevit import forms
import os
import wpf
from System.Windows import Application, Window
def test2(data):
    print "after wpf class ..."
    print data
class MyWindow(Window):
    def __init__(self):
        wpf.LoadComponent(self, os.path.dirname(__file__) + '\\test.xaml')
    def Button_GO(self, sender, e):
        disciplines = []
        for i in range(10, 15):
            moa = eval("self.ChkBox" + str(i))
            if moa.IsChecked:
                disciplines.append(str(i))
        print "inside wpf class"
        print disciplines
        test2(disciplines)
if __name__ == '__main__':
    MyWindow().Show()
and...
Please help ! :'(
4 REPLIES 4
Hi @jerome.leignadier,
The key to interacting with Revit API from outside threads is done either inside a handler of an Idling event or an External Event.You need to use an ExternalEvent to interact with Revit in a non modal windows. The ExternalEvent allows you to enter within a valid Revit API context.
Detailed explanation of driving Revit from outside can be found here:
https://thebuildingcoder.typepad.com/blog/2015/12/external-event-and-10-year-forum-anniversary.html.
To understand the concept clearly from pyRevit point of view, I would recommend you take a look at this resource specifically: https://pythoncvc.net/?p=247
Carol Gitonga, Developer Advocacy and Support, ADN Open
Hi
Thank you for your response but ...
I have already explored these links and they have not helped me (one is in C# so the syntax difference is frozen to transpose the solution ; the other offers code that is not functional ... it is difficult to understand how to correct a code with another code that must also be corrected)
I try this one to : https://stackoverflow.com/questions/61793050/pyrevit-wpf-non-modal-trouble
but with the same result (dirty crash)
Do you have an example that works ?
Hi there,
Im not that much into Python as into C#, but having a brief look at yout problem, it sounds like casting of sender object in your events may not be correct,
Let us know whether that helped,
Best, Lukasz
I find the solution : Lesson 10. WPF forms. User Interface
Forma Design Contest
Rail Community
