revit 2018.3 error
revit 2018.3 error
revit 2018.3 error
i'm using revit 2018.3 and i'm working in one local file and one detached file in the same file. then i close detached model but detached model and central file also closing without information or  warning and it's not showing recent file screen it's revit is shutdown completely. so what is the problem anybody know this.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Are you doing anything programmatically?
This forum is only for Revit add-on development.
For non-API questions, please choose another forum that is more appropriate.
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
For Revit Architecture (including common platform product usage questions):
https://forums.autodesk.com/t5/revit-architecture-forum/bd-p/133
I hope this helps
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
THANK YOU
