Revit 2018.2 SDK
Revit 2018.2 SDK
GHASEM_ARIYANI
Advisor Advisor
Message 1 of 12
Revit 2018.2 SDK
GHASEM_ARIYANI
hello everyone
i downloaded Revit 2018.2 SDK, but RevitAPI.chm not open.
what is problem?
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
Replies (11)
Message 2 of 12
stever66
Maybe it didn't install correctly.  If you re-run the installer, there is a "repair" option.
Or you might try in-installing, and reinstalling.
Mine installed in a strange directory - not the same location as where I saved the installer file.  It defaulted to the 😧 drive.  I didn't even know I had a D drive.
Message 3 of 12
Message 4 of 12
GHASEM_ARIYANI
Unfortunately not solved my problem
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 5 of 12
Unchecking the box "Always ask...when opening this file..." has worked for each of the .chm files I used until now. Did you try that also?
Message 6 of 12
so-chong
hi, your folder name called "C#". on some post the "#" may cause the problem to open the file correctly.
try to rename the folder(e.g. "csharp") or move the file somewhere else.
i hope this helps.
Message 7 of 12
GHASEM_ARIYANI
hello sir @so-chong
Thanks a lot
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 8 of 12
so-chong
glad it helps.
be aware there's an online version of the Revit API.
http://www.revitapidocs.com/
2018.2 is not yet available, but it won't be long. i think.
Message 9 of 12
Strange, I have tried to put mine in a folder called C# and it's does not seem to cause any particular trouble...
Message 10 of 12
so-chong
yes, it's strange.
i have just created a folder called C# and get the same result as gh_ar (can't display chm file)
I have a Windows 10 64 bits desktop, i'm not sure how this works with e.g. Windows 7 or 8 32 or 64 bits.
It has to be Windows related (security) settings.
Message 11 of 12
I see, you are right, what I had placed in the C# folder was a shortcut to the file that has been installed in the RevitSDK folder. When I put any original .chm file in this C# folder, it does not work either. Not totally sure but it could be related to html naming conventions...
Message 12 of 12
GHASEM_ARIYANI
Yes, I know it online
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
