07:12 AM
I cannot open the help files in Revit Student Edition 2016. I get an error saying "Filename, directory name or volume label syntax is incorrect." Attached is the Revit.ini file. No solution previously provided has worked for me. I'd like to use either the online or offline help files, whichever is easier to fix. I think this a fault in the program itself. The help files should open without having to edit an .ini file. I've seldom seen this before in any product. Kindly provide a fix for the Revit.ini file and for the 2016 edition itself so that the help file will open on its own.
