Revit 2016 Help Module Error
After the Revit 2016 offline help module was installed I get a message that "The filename, directory name, or volume label syntax is incorrect."  This error message occurs when all dropdown menu options are selected.
The help module has also asked that a 64 bit installer be used instead of a 32 bit installer. I am certain the 64 bit edition of the base Revit 2016 program was selected and installed.
Any ideas
rosalesduquej
Most likely you will not get an answer from this forum since
Revit API forum is for API (Application Programming Interface) questions.
For non-API questions, please choose other forums that is more appropriate. For example,
Installation and licensing:
http://forums.autodesk.com/t5/installation-licensing/bd-p/24
Revit Architecture (including common platform product usage questions):
http://forums.autodesk.com/t5/revit-architecture/bd-p/133
Revit Structure:
http://forums.autodesk.com/t5/revit-structure/bd-p/153
Revit MEP:
http://forums.autodesk.com/t5/revit-mep/bd-p/188
Thank you for understanding.
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
