Revit 2015 / COBie Toolkit fatal error
August_PAD
August_PAD
When running the COBie Toolkit extension for Revit 2015, I can run the setup normally and COBie schedules are created.  When I access the Modify dialog, if I select either the "Zone Manager" or "Elements to be Exported" buttons, I first receieve a "system.notimplementedException" error (see attached image).
Once I exit the error dialog, if I select either of those buttons again, I get a fatal error and the program closes.
It does not matter what order or combination of those buttons I press, the results are the same.  However, the "Batch Modify Other Fields" button appears to function normally; the dialog opens with no errors.
I have uninstalled / reinstalled the extension and that has not helped.  I've tried multiple Revit files and always get the same result.  I am able to successfully run the COBie extension on Revit 2014 and 2016 without issue. Running Widnows 7 Pro - 64bit.
Anyone know what the problem is and/or how to resolve it?
Thanks for any help!
August_PAD
Problem may have been solved. I updated A360 Collaboration to v7.1 and now it appears to be working.
