Revisions on sheet
Revisions on sheet
chris.slattery
Revisions on sheet
chris.slattery
Does anyone know if there is a way to access the Revisions on Sheet parameter? I would like to add that to a drawing list table so I can turn these on and off from one location instead of selecting each sheet one at a time.
Yien_Chao
it's a good one...
to get all revision on a sheet you will need .GetAllRevisionIds().
let's say Rev_List = sheet.GetAllRevisionIds()
to add revision, you will need to add the revision to the existing  list of ids (revision's ids)
Rev_List.Add(id)
and to set set revision on sheet is :
sheet.SetAdditionalRevisionIds(Rev_List)
And i assume you want to do it by an Excel schedule?
chris.slattery
I did not think of doing it in Excel. I was thinking to just have a list of the sheets in a Revit Drawing List with new columns for the Revisions on Sheet with a yes or no and have that turn on the revision on those sheets. At least that would be all in one location and I could select several sheets at one time and change it to yes or no.
