Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revision cloud nomenclature
1 REPLY 1
PhilippeC_Micro
172 Views, 1 Reply
In Revit 2024, there's a new function for creating revision cloud nomenclatures. These allow you to see the comments entered in a revision clouds and which revisions they are associated with. However, it is not possible to know on which page/plan/elevation they are located. How can I create a "location" field?
1 REPLY 1
If you are interested in this from a Revit API programming point of view, you can snoop the elements and explore their properties and relationships using RevitLookup.
If you are looking from an end user perspective, I am afraid you are asking in the wrong place. Please note that this discussion forum is dedicated to programming Revit using the Revit API. Afaict from your description and screen snapshot, you are not doing anything programmatically yourself using the Revit API, just using the standard Revit user interface. In that case, you might get more optimal answers to a question like yours relating to product setup, optimisation, usage, and other end-user support issues in one of the non-API Revit product support discussion forums instead:
Rail Community
