Return Reference to Location
Mark.Ackerley
Mark.Ackerley
Hi All,
Thanks in advance for your help.
I am  using Python (in Dynamo but this seemed more of an API question, apologies if it is out of place).
I'm trying to place families along pipes from a linked file.
The pipes can be horizontal or vertical.
I want to place the family centered on the the pipe location line.
I am looking to use this new family by instance method  https://www.revitapidocs.com/2018/4545a04f-b5e8-1921-5a4c-d734bc4874ca.htm
I know that I can set my Revit view to Coarse and Tag the Geometry (which appears to be the location line, I don't seem able to return this model line from the element geometry, only a solid).
However, when I try to return References to the linked Element, I appear only to be able to return them from the Element Solid Faces / Edges.  If I create family from these, it fails because the placemenet / location line is not on the Reference (surface).
I can possibly establish the Face / Edge which aligns with the placement / location line, place my family and shift it back, but it seems incongruous.
I would be very grateful if anyone had a suggestion for how to return the Reference to the Location Line (which I am able to use for Tagging).
This link seemingly manages to tag an element without needing to return solids, but it seems to fail in Python, and the API doesn't have a create reference method, so I am obviously not understanding something! https://thebuildingcoder.typepad.com/blog/2019/05/tagging-a-linked-element.html
All assistance greatfullly received.
Mark
zrodgersTSSSU
Is there a reason it has to be a reference. Could you just get the pipes location curve then use that as the placement point for the tag? Something like:
foreach (ElementId elemId in selectedIds)
                    Element elem = uidoc.Document.GetElement(elemId);
                    Curve eleCurve = (elem.Location as LocationCurve).Curve;
                    //evaluate curve
Then get the midpoint or evaluate at a certain distance.
Mark.Ackerley
Thanks for your response.
I actually found that I had to use a face reference to place a line-based family, so I didn't pursue this any further.
Kind regards,
Mark
