Retrieve omniclass number from selected element
    I would like to know how to retrieve the omniclass number from a particular object with a shared parameter assocaited programmatically. I have checked the family of the object which has a omniclass number associated. I am also able to use schedule to retreive the omniclass number but when I use the following code, it always return null
Autodesk.Revit.DB.Document doc = commandData.Application.ActiveUIDocument.Document;
BuiltInParameter _bipCode = BuiltInParameter.OMNICLASS_CODE;
BuiltInParameter _bipDesc = BuiltInParameter.OMNICLASS_DESCRIPTION;
UIApplication app = commandData.Application;
ElementId id = new ElementId(_bipCode);
ParameterValueProvider provider = new ParameterValueProvider(id);
FilterStringRuleEvaluator evaluator = new FilterStringGreater();
FilterRule rule = new FilterStringRule(provider,evaluator,"", false);
ElementParameterFilter filter = new ElementParameterFilter(rule);
FilteredElementCollector collector = new FilteredElementCollector(doc);
collector.WherePasses(filter);
ICollection<Element> allElements = collector.ToElements();
ICollection<Application.Record> filteredList = new List<Application.Record>();
foreach (Element element in allElements)
if (element.get_Parameter(_bipCode) != null)
omni_counter++;
omiclass = element.get_Parameter(_bipCode).AsString();
else
omiclass = null;
if (element.get_Parameter(_bipDesc) != null)
omiDesc = element.get_Parameter(_bipDesc).AsString();
else
omiDesc = null;
link = null;
foreach (Parameter p in element.Parameters)
if (p.Definition.Name.Equals("Item_no"))
link = p.AsString(); //crucial to use AsString() instead of ToString()
break;
if (link != null && link.Length > 0)
counter++;
if (omiclass != null) bi_counter++;
Mustafa.Salaheldin
I used the same code and it returns values. !!! If you can provide sample projrct this may help to figure out what is wrong.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
