Retrieve dimensions values from a Fabrication Part
novesvalentin
novesvalentin
I'm trying to get the value of the dimensions of a Fabrication Part, but I can't find those parameters in Element.Parameters Property.
Which property or method are you using to retrieve those parameter
Thanks!
If this helped solve your problem please mark it as solution, so other users can get this solutions as well.
Valentin Noves
BIM Manager
www.valentinnoves.com
Revitalizer
I've never worked with FabricationParts, but using the methods provided by the class, I would suppose:
public static Dictionary<string, double> GetValues(FabricationPart fp)
    Dictionary<string, double> dict = new Dictionary<string, double>();
    foreach(FabricationDimensionDefinition fdd in fp.GetDimensions())
        dict.Add(fdd.Name, fp.GetDimensionValue(fdd));
    return dict;
I didn't test this.
There is also a GetCalculatedDimensionValue() method, that seems to be a Parameter's AsValueString() pendant.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
