Retrieve Dimension Style by name using python
lucas-gsbp
Message 1 of 9
lucas-gsbp
Hi, I am trying to collect a certain dimension style by name.
dTypes = FilteredElementCollector(doc).OfClass(DimensionType)
dimensionTypes = []
for i in dTypes:
	dimensionTypes.append(i.Name)
But I am getting an error "AttributeError: Name"
According to the Revit API Docs:
https://www.revitapidocs.com/2019/a6f6655d-3383-a0ea-670d-0bbe6d2bb964.htm
Name is a property of the Dimension Style Class.
Using PyRevit.
Thanks!
Replies (8)
Message 2 of 9
Yien_Chao
every type is a Symbol in API.
so use : i.get_Parameter(BuiltInParameter.SYMBOL_NAME_PARAM).AsString()
Message 3 of 9
Yien_Chao
I meant  type from system famillies.
Message 4 of 9
lucas-gsbp
It worked, indeed but would you happen to know why it works for C# and not python?
Why python can't read the name property of this particular class?
Message 5 of 9
Yien_Chao
Does .Name attribute  works with C# ?
Message 6 of 9
lucas-gsbp
Well at least for me it did. I am not sure why it wouldn't work.
Message 7 of 9
Yien_Chao
https://www.revitapidocs.com/2018.2/8757156f-79ec-fdff-e74d-7c86e576b73e.htm
the .FamilyName seems to work fine, but the .Name is use to Set, not to get.
Message 8 of 9
lucas-gsbp
You are correct. I went and Checked I did use the FamilyName property.
The problem lied on the fact that using python would return the system family name and using C# I would get the dimension style Name.
Message 9 of 9
Yien_Chao
on the other hand, you can use .Name attribute with Revit FamilyInstance and Element.
i guess the attribute is not used for the same reason on ElementType, because if just for setting.
