Retrieve a Material ID via api & assign to an Integer Variable
AdvancedBIMSystems
AdvancedBIMSystems
I can obviously Snoop DB with RevitLookup to obtain a named Material Id :Capture.JPG
How would I go about this with code, assuming I know the material name already?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @AdvancedBIMSystems ,
Try using this below code
FilteredElementCollector collector= new FilteredElementCollector(doc).OfClass(typeof(Material));
                IEnumerable<Material> materialsEnum= collector.ToElements().Cast<Material>();
                var materialReturn1 = from materialElement in materialsEnum where materialElement.Name.Contains("Your MATERIAL NAME") select materialElement;
                Material material = materialReturn1.First() as Material;
                //Material ID
                int materialId = material.Id.IntegerValue;
 I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
RPTHOMAS108
By some form of filtering e.g.
public Result TObj121(Autodesk.Revit.UI.ExternalCommandData commandData, ref string message, Autodesk.Revit.DB.ElementSet elements)
			UIApplication UIApp = commandData.Application;
			UIDocument UIDoc = UIApp.ActiveUIDocument;
			if (UIDoc == null)
				return Result.Cancelled;
			Document Doc = UIDoc.Document;
			FilteredElementCollector FEC = new FilteredElementCollector(Doc);
			ElementClassFilter ECF = new ElementClassFilter(typeof(Material));
			List<Element> Mats = FEC.WherePasses(ECF).ToElements().ToList();
			Element Mat_El = Mats.Find(x => x.Name == "Gold");
			if (Mat_El == null)
			int M_Id = Mat_El.Id.IntegerValue;
			return Result.Succeeded;
AdvancedBIMSystems
Thanks very much, that works perfectly!
