Results of Generative Design
hoang_tv
hoang_tv
I would like to inquire about how Generative Design operates.
As far as I understand, when using the same Revit model and settings such as 'Population size', 'Generation', and 'Seed', the results of each run are identical.
However, if I copy that Revit model to another PC, will the results still be the same as on the original PC?
jeremy_tammik
I would suggest exploring this from a manual end user point of view first, and checking the online help on this topic:
Please note that this discussion forum is dedicated to programming Revit using the Revit API. Afaict from your query, you are not doing anything programmatically yourself using the Revit API, just using the standard Revit user interface. In that case, you will probably get more optimal answers to a question like yours relating to product setup, optimisation, usage, best practices and other end-user support issues in one of the non-API Revit product support discussion forums instead:
