Message 1 of 12
Results Explorer. error message in Revit 2022
since Revit 2022 we have issues with the "Result Explorer". We export our results to Revit and try to display them. Since version 2022 following message shows up:
Only change to our api code was to use ForgeTypeId for units as required with new version 2022.
You can see this error, when you open attached file and try to explore results.
If we export only Forces or Moments that issue doesn't show up. The export of deflections (deformations) is causing that error. We are however not sure what is causing the error exactly. Could you help us to track it down?
In case you need further information don't hesitate to contact me.
Greetings Jaroslav Kopecký.
