Render Material Texture Image
Do we have access to a material's texture image thru Revit's API, and/or Dynamo?
jeremytammik
Dear Trevor,
Thank you for your query.
Yes, we do.
Eason Kang explains how to access it in his explanation how to show a Revit custom texture map in the Forge Viewer:
https://forge.autodesk.com/blog/show-revit-custom-texture-map-viewer
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Thank you much, for the information.
My scenario:
I have an IFC opening in Revit with materials attached to it's surfaces, but their assets are blank/grayed out, with no path to its texture image file.  My thought was to feed the materials with texture's image path via Excel & Dynamo.  Creating materials via Excel & Dynamo seams to be possible, but cant seam to add image file path.  Is this possible?
