Renaming views after creation
Hi All,
I'm creating a routine that creates new plan views (structural plans) from the structural plans that are in my project, but these new structural plans will have a different view template.
The portion of the routine I made is as follows:
using (Transaction tx = new Transaction(doc, "View Creation"))
                    tx.Start();
                    // Create new views with desired template applied
                    foreach (View v in plantas)
                        ElementId levelId = v.GenLevel.Id;
                        ViewPlan vista = ViewPlan.Create(doc, vft.Id, levelId);
                        vista.Name = vista.Name + " - Thick";
                        vista.Name.Replace("(1)", "");
                        // Apply the template
                        vista.ViewTemplateId = vTemplate.Id;
                    tx.Commit();
The problem is, that when I do this, Revit prompts a message telling that a unique name is needed, but in my code, after the view creation, I set a different name.
What am I missing here?
Thanks in advance!
I found the solution to my problem. I had a repeated plan view that was making troubles.
My bad.
Cheers!
jeremytammik
Dear Jorge,
Congratulations on solving your task.
Thank you for your update and letting us know.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
