Rename Line Patterns
raymondlooRAB85
raymondlooRAB85
We are exploring using macros to automatically rename line patterns across hundreds of loadable families in line with new company standards.
As I'm new to using macros, I stumbled upon this web page which allows a prefix to be added to line patterns. I tested it and it seems to work fine.
https://www.modelical.com/en/node/revit-api-rename-line-patterns/
However, we are needing to replace the line pattern name's prefix with a different one. The above macro only adds a new prefix (ie. I can't seem to remove the existing prefix). Any advice on what modifications to this macro would be needed would be much appreciated.
eg. Old name = ABC-Dash_Dot
New name = DEF-Dash_Dot
Many thanks in advance.
jeremy_tammik
Yes, sure we can help. That is a very simple task. All you need to do is to use one or two of the numerous and powerful string manipulation methods provided by C# and other .NET languages:
In your specific case, you want to replace a string in a string:
I don't think I need to spell it out further still, do I?
Good luck and have fun!
And congratulations on the luck of finding such a suitable starting point for your endeavour.
raymondlooRAB85
Hi Jeremy,
Many thanks for your help! After a bit of trial and error I think the issue is resolved.
I used StringBuilder to replace part of the line pattern name. Is there a way to batch run macros across multiple families?
jeremy_tammik
Good for you, congratulations. As said, there are many possible ways to achieve that.
The same applies for batch processing documents, both RVT and RFA. Here are some suggestions from The Building Coder:
raymondlooRAB85
Thank you Jeremy for your help. We will take a look at what The Building Coder has to say.
