Rename Imported CAD Objects ?
s04049
s04049
How can i Rename the imported CAD Object through the Revit API?1-27-2016 12-54-45 PM.jpg
Revitalizer
as far as I can see, the ImportInstance's CADLinkType.Name property can be set.
Give it a try.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
s04049
CADLinkType.Name only change the Type name of the dwg.(Like the image below)
so far i can get the Category of dwg by
doc.Settings.Categories.get_Item(dwg.name);
but i don't know how to edit it.
I have the same problem. I can change material but not rename layer. Please let me know
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
public class ViewCategories : IExternalCommand
public Autodesk.Revit.UI.Result Execute(ExternalCommandData commandData,
ref string message, ElementSet elements)
try
UIDocument uidoc = commandData.Application.ActiveUIDocument;
Document doc = uidoc.Document;
View view = doc.ActiveView;
using (Transaction t = new Transaction(doc, "Change Imported dwg visibility"))
t.Start();
String prompt = "";
foreach (Category cat in view.Document.Settings.Categories)
if (cat.Name.StartsWith("Imported in families"))
CategoryNameMap objA = cat.SubCategories;
CategoryNameMapIterator objB = objA.ForwardIterator();
while (objB.MoveNext())
Category cat2 = objA.get_Item(objB.Key);
switch (cat2.Name.ToUpper())
case "LAYERFOUND":
cat2.Material = getMaterialFromName("NewMaterialName", doc);
break;
default:
break;
TaskDialog.Show("Revit", prompt);
t.Commit();
catch (Exception e)
message = e.Message;
return Autodesk.Revit.UI.Result.Failed;
return Autodesk.Revit.UI.Result.Succeeded;
info
Someone can help with this issue?
I have the same problem..
Is there any way to rename an imported layer in Revit ?
Thanks, Thomas
Ning_Zhou
hi Revitalizer, are you sure ImportInstance's CADLinkType.Name property can be set?
