Rename a project parameter
Message 1 of 1
I would like to know if anyone knows how to rename a parameter within a project? I have been able to get the parameter definitions using the following method. But I think I might need the parameter element to be able to rename it.
    Public Function Test_GetParameters(ByRef docActiveDoc As Autodesk.Revit.DB.Document) As System.Collections.Generic.List(Of Definition)
        Dim IList As New List(Of Definition)
        Dim objParameterBindings As BindingMap = docActiveDoc.ParameterBindings
        Dim ElementIter As IEnumerator
        ElementIter = objParameterBindings.ForwardIterator
        Dim it As DefinitionBindingMapIterator = objParameterBindings.ForwardIterator()
        While it.MoveNext()
            Dim def As Definition = it.Key
            MsgBox(def.Name)
            If def.Name.Equals("Test123") Then
                'objParameterBindings.Remove(def)
                'def.Name = "Test1234"
                'def.
        End While
        Return IList
    End Function
Kind Regards
David
Replies (0)
