Removing paint from a split face
hzamani
Message 1 of 8
hzamani
I'm trying to remove painted material from faces of elements. This works fine on non-modified elements, but when an element's face has been split and the split faces are painted separately the code below doesn't work. Any ideas?
using (Transaction t = new Transaction(doc, "Removing Paint From Selected Elements"))
    t.Start();
    foreach (Element elem in Elements)
        GeometryElement geomElement = elem.get_Geometry(geoOptions);
        IEnumerator<GeometryObject> geomObjectEnumerator = geomElement.GetEnumerator();
        while (geomObjectEnumerator.MoveNext())
            Solid solid = geomObjectEnumerator.Current as Solid;
            if (null != solid)
                foreach (Face face in solid.Faces)
                    doc.RemovePaint(elem.Id, face);
    t.Commit();
Replies (7)
Message 2 of 8
hzamani
Never mind! Updated the code to this and now it works:
    t.Start();
            if (null != solid)
                    if (face.HasRegions)
                        var regions = face.GetRegions();
                        foreach(Face regFace in regions)
                            doc.RemovePaint(elem.Id, regFace);
                    else
    t.Commit();
Message 3 of 8
Revitalizer
each of the regions could be divided into another set of faces, so I would add a recursion.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 4 of 8
jeremytammik
Dear Hoss,
Thank you for your query, and many thanks to Revitalizer for his important suggestion.
I think he meant to say: "each of the region's faces could be divided into another set of regions, ..."
Here is an untested attempt at adding recursion to your code:
  void RemovePaintFromFace( Element e, Face face )
    Document doc = e.Document;
        RemovePaintFromFace( e, regFace );
    else
      doc.RemovePaint(e.Id, face);
With that in place, in your code above, you can replace the contents of the foreach loop over the solid faces by one single call to the recursive method:
    RemovePaintFromFace( elem, face );
I hope this helps, matches Revitalizer's suggestion and works as desired.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 5 of 8
hzamani
Spot on Jeremy. Thanks.
Message 6 of 8
hzamani
Thanks Revitalizer for the comment. I just tried splitting an already split face and it looks like even if the a face get further split, all the instances will be returned using the GetRegions method on the original face (so no recursion would be required). Is what I did, what you meant by "regions could be divided into another set of faces"?
Message 7 of 8
Revitalizer
I just tested it; I must admit that you are correct.
Sorry for confusion - I was mislead by UI behaviour.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 8 of 8
hzamani
Thanks Revitalizer, your suggestion seemed completely logical to me too. But I've also learned that one can get surprised by Revit sometimes. For the sake of completeness, I found that there are instances where my second code doesn't work. I found that the best approach is to RemovePaint on any face whether it's split or not. So the more reliable code will be:
