Removing Add-in Generated Files on Uninstall
I have developed a Revit add-in that generates a txt file during its execution. The issue I am facing is that this file remains on the system after the add-in is uninstalled. Since the installer is built by Autodesk for the App Store, I do not have direct control over the uninstallation process.
I would like to know:
- What is the recommended approach for ensuring that files generated during the add-in's execution are removed upon uninstallation?
- Are there any best practices for handling this within the Revit API?
- Should I explicitly delete the file within my add-in code when Revit closes, or is there another preferred method?
Any guidance or suggestions would be greatly appreciated!
Thank you in advance 😉
