Remove Warning/message Duplicate Types
Hi
I am copying Objects from a linked Model, but I got a lot of "warnings" about Duplicate Types, I want to suppress this message.
I have tryied the legendary "WarningSwallower" from Mr, J. Tammik, but the "Duplicate Types" message is not a Warning.
How do I remove this message ?
Regards
Anders
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Simple set the copy options to ignore such warning messages
CopyPasteOptions options = new CopyPasteOptions();
Options.SetDuplicateTypeNamesHandler(new MyCopyHandler());
The class MyCopyHandler is an implementation of the IDuplicateTypeNamesHandler
public MyCopyHandler : IDuplicateTypeNamesHandler
   public DuplicateTypeAction OnDuplicateTypeNamesFound()
      return DuplicateTypeAction.UseDestinationTypes;
I hope this helps.
If this helped solve your problem please mark it as solution, so other users can get this solutions as well
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
ed_sa
   }  this didn't sovle teh problem. it kept asking ok or cancel on duplicate type window
laurenkschmidt
I just had this issue, and then realized I wasn't connecting the options in the copy command. Silly mistake, but easy to make if you already have your copy working. So, after you make the options, be sure that you're using them.
ElementTransformUtils.CopyElements(source, elemIds, destination, transform, options);
