Remove or Hide a Ribbon Tab
basionyecg
Message 1 of 9
basionyecg
I am familiar with adding a Ribbon Tab Programmatically
public static UIControlledApplication UiCtrApp;
public Result OnStartup(UIControlledApplication application)
                UiCtrApp = application;
                UiCtrApp.CreateRibbonTab("New Tab");
                return Result.Succeeded;
but I don’t seem to find a way to remove or hide the tab at a certain point in runtime, How can I do that?
Ragards,
Basiony
Replies (8)
Message 2 of 9
rosalesduquej
I found a post on the Builder Coder which Dynamically Hides and Displays a Ribbon panel.
http://thebuildingcoder.typepad.com/blog/2013/07/dynamically-hide-and-display-a-ribbon-panel.html
Hope this helps,
Cheers,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
Message 3 of 9
basionyecg
Thanks Jaime , but it seems that it is not the same case for tabs.
Basiony
Message 4 of 9
eN27
Try this one :
Autodesk.Windows.RibbonTab      revitRibbonTab = UIFramework.RevitRibbonControl.RibbonControl.FindTab(tabName);
revitRibbonTab.IsVisible = false;
You need also add reference to AdWindows.dll  to have access to things from Autodesk.Windows  namespace;
Message 5 of 9
Revitalizer
there is a workaround using the AdWindows.dll:
using Autodesk.Windows;
Then, OnStartup, register for ViewActivated event.
When triggered, call this function:
private void DisableTab()
    Autodesk.Windows.RibbonControl ribbon = Autodesk.Windows.ComponentManager.Ribbon;
    foreach (Autodesk.Windows.RibbonTab tab in ribbon.Tabs)
        if (tab.Title="yourTabTitle")
            tab.IsVisible = false;
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 6 of 9
Revitalizer
Didn't see your post, you already provided the solution.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 7 of 9
rosalesduquej
Oh well yes, using AdWindows.dll it sure can be achieve :). Just remember that this Dll is not supported by Autodesk, so any odd functionality that this may cause, we cannot support it.
Thank you Revitalizer for pointing out the solution 😉
Cheers,
Jaime Rosales D.
Message 8 of 9
Revitalizer
Hey Jaime,
eN27 provided the answer first, don't forget 😉
Rudi
Rudolf Honke
Software Developer
Mensch und Maschine
Message 9 of 9
fernando.pavonC234G
Thanks for your reply, but where do we find UIFramework?
