Reload Link CAD
Reload Link CAD
Message 1 of 14
Reload Link CAD
Hi there,
I wonder if we could programmatically reload linked CAD in Revit
This need comes from my actual works since I usually reload linked CAD to keep track of the changes every time the linked CAD is revised. And I found it extremely annoying when I need to repeatedly open the Manage Links >> switch to CAD Formats >> find a link in the very long list of Linked CAD >> Reload
I skimmed through many posts related to this issue but none of them seem to be able to address this issue
I am playing around with the outline idea shown in the below code
Hope to some can help me out
Thank you
Nguyen Duy Hoa
public void ReloadLinkedCAD(Document doc)
	IList<ImportInstance> importIntaces = new FilteredElementCollector(doc).OfClass(typeof(ImportInstance)).Cast<ImportInstance>().Where(i => i.IsLinked == true).ToList();
	using (Transaction t = new Transaction(doc, "Reload Imports"))
		t.Start();
		foreach (ImportInstance ints in importIntaces)
			if (ints.Category.Name.EndsWith(".dwg"))
				ElementId typeId = ints.GetTypeId();
				CADLinkType cadLink = doc.GetElement(typeId) as CADLinkType;
				//How to reload cadLink?
		t.Commit();
Replies (13)
Message 2 of 14
jeremytammik
Dear Duy Hoa,
Read the Revit API Help file RevitAPI.chm:
RevitLinkType.LoadFrom Method (ModelPath, WorksetConfiguration)
Loads or reloads the Revit link from disk. The link will be loaded from the input path.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 14
Dear Mr. Jeremy,
Thank you for your sugestion
You are perfectly correct in your reply that we can programmatically reload RevitLinkType instances, however, what I want to reload is CadLinkType (not RevitLinkType), this is where the problem lie
I had cheked the RevitAPI.chm and found that CadLinkType class is not equipped with any method for loading or reloading
May I have any other advices?
Thank you
Nguyen Duy Hoa
Message 4 of 14
Audun_Opdal
Did you find any solution on this ?
Audun
Message 5 of 14
jeremytammik
Dear Duy and Audun,
I am checking with the development team.
Thank you for your patience.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 6 of 14
Dear Mr. Jeremy,
Thank you for your attention
This matter is such a need in my routine job
Please inform us when you get the solution
Look forward to hearing good news from you
Thank you,
Nguyen Duy Hoa
Message 7 of 14
jeremytammik
Dear Nguyen Duy Hoa,
The development team reply:
You cannot currently reload CADLinkType directly in any released version.
You can however use the TransmissionData class to request a “reload from this new file the next time I open the document”:
http://thebuildingcoder.typepad.com/blog/2011/03/many-issues-resolved.html
http://thebuildingcoder.typepad.com/blog/2011/10/using-the-writetransmissiondata-method.html
http://thebuildingcoder.typepad.com/blog/2011/11/access-transmissiondata-of-central-file-on-revit-se...
I hope this helps.
Best regards
Jeremy
Jeremy Tammik
The Building Coder
Message 8 of 14
Dear Mr. Jeremy,
Thank you for your endeavor in finding the reply for my concerned issue
I will give that a try and will inform you the result later
Best Regards,
Nguyen Duy Hoa
Message 9 of 14
Any chance this has changed in the last 4 years?
This function is the only piece I'm missing in a revision control project.
Message 10 of 14
Message 11 of 14
Hi
I want to reload a CAD Link from an other path (the File Server have got at new name:- ), but can't make it work
Is that not possible or do I make somethoing wrong ??
NewPath is the fullpath to the CAd file
 foreach (CADLinkType CADtypeLink in CADlinkInstances)
       ExternalFileReference er = CADtypeLink.GetExternalFileReference();
       ModelPath mp = er.GetPath();
       string userVisiblePath = ModelPathUtils.ConvertModelPathToUserVisiblePath(mp);
       String NewPath = userVisiblePath.Replace(Paths[0], Paths[1]);
        if (!File.Exists(NewPath))
            MissingPaths.Add(NewPath);
         else
              LinkLoadResult CAD_LLR  = CADtypeLink.LoadFrom(NewPath);
Regards Anders
Message 12 of 14
@Anonymous
Are the current paths relative?
I'm not sure how you're constructing 'Paths', but you might need to call some MakeAbsolute() function on Paths[1] before userVisiblePath.Replace().
From documentation for CADLinkType.LoadFrom (my underline):
Parameters
path Type: System String
A path on disk giving the location of the linked file. This path must be absolute. The link's path will remain PathType.Absolute or PathType.Relative, whichever it was before. If the link was previously to an external server location, the path type will be relative.
Message 13 of 14
Hi
Thanks, is helped to set the path to absolut, in Revit before making the changes 😉
Transaction Tr = new Transaction(doc, "Change Paths");
Tr.Start();
ModelPath mp = er.GetAbsolutePath();
String NewPath = userVisiblePath.Replace(Paths[0], Paths[1]); // replacing the old servername with the new servername
MissingPaths.Add(NewPath); // making a list of missing paths
else
try
catch (Exception ex)
TaskDialog.Show("Error", ex.ToString());
Tr.Commit();
Message 14 of 14
Hi @Anonymous , How about the method to reload a cad link in the version of 2016 ?
