Register Services (Dependency Injection)
jmadeley37KVE
Message 1 of 9
jmadeley37KVE
Hi all,
I'm looking for a way to register services such as a Logger with Revit so that it can be called later on using Dependency Injection.
I've previously worked with ASP.NET applications with the usual Startup.cs and IHost but can't seem to find the IServicesCollection through the IExternalApplication interface.
Can anyone provide some suggestions?
Jack
Replies (8)
Message 2 of 9
mhannonQ65N2
As far as I can tell, there is nothing like that in Revit. If you want some sort of dependency injection container, you'll need to write your own or use a 3rd party library. Revit uses the Castle.Windsor library so if you want to use that you'll need to use the same version that Revit ships with (3.2.1.20 for Revit 2020 and 2023).
Message 3 of 9
jmadeley37KVE
Thanks!
I'll take a look around in that case and see if I can engineer a solution.
If I come up with anything I'll be sure to post back here.
Message 4 of 9
Kennan.Chen
I use a self-implemented DI container to host services in my application and it works completely fine.
Message 5 of 9
jmadeley37KVE
Hi Kennan,
Would you be able to provide a high-level overview of how you have structured your solution?
Are you using external libraries or Microsoft's own implementation of dependency injection?
Jack
Message 6 of 9
Kennan.Chen
The simple definition of my container, which is an extended interface based on the System.IServiceProvider
/// <summary>
///     Use to manage instances and the creation of instances
/// </summary>
public interface IContainer : IDisposable, IServiceProvider
    #region Others
    /// <summary>
    ///     Get an instance of a specific service
    /// </summary>
    /// <typeparam name="TService">The type of the service</typeparam>
    /// <returns>The instance of the service</returns>
    TService GetService<TService>();
    /// <summary>
    ///     Inject the instance properties from the <see cref="IContainer" />
    /// </summary>
    /// <param name="instance">The instance to inject</param>
    void InjectProperties(object instance);
    /// <summary>
    ///     Register the type of the service to the container
    /// </summary>
    void Register<TService>();
    /// <summary>
    ///     Register the type of the service to the container with the implementation type
    /// </summary>
    /// <typeparam name="TImpl">The implementation type</typeparam>
    void Register<TService, TImpl>() where TImpl : TService;
    /// <summary>
    ///     Register the type of the service to the container with a delegate to create the instance
    /// </summary>
    /// <param name="instanceCreator">The delegate to create the service instance</param>
    void Register<TService>(Func<TService> instanceCreator);
    #endregion
The simple implementation of IContainer which is a singleton
public class SimpleContainer : IContainer
    #region Constructors
    static SimpleContainer()
        Container = new SimpleContainer();
    private SimpleContainer()
        this.Singleton<IContainer>(this);
    #endregion
    #region Properties
    public static IContainer Container { get; }
    private static ConcurrentDictionary<Type, IEnumerable<PropertyInfo>> InjectableProperties { get; } =
        new ConcurrentDictionary<Type, IEnumerable<PropertyInfo>>();
    private Dictionary<Type, Func<object>> Registrations { get; } = new Dictionary<Type, Func<object>>();
    #endregion
    #region Interface Implementations
    public T GetService<T>()
        return (T) GetService(typeof(T));
    /// <summary>
    ///     Inject the properties attributed with InjectAttribute
    /// </summary>
    /// <param name="instance">The instance</param>
    public void InjectProperties(object instance)
        if (null == instance) return;
        GetInjectableProperties(instance)
            .ToList()
            .ForEach(property => { property.SetValue(instance, GetService(property.PropertyType), null); });
    public void Register<TService>()
        Register<TService, TService>();
    public void Register<TService, TImpl>() where TImpl : TService
        InternalRegister<TService>(() =>
            var implType = typeof(TImpl);
            return typeof(TService) == implType
                        ? this.CreateInstance(implType)
                        : GetService(implType);
    public void Register<TService>(Func<TService> instanceCreator)
        InternalRegister<TService>(() => instanceCreator());
    public void Dispose()
        Registrations.Clear();
    public object GetService(Type serviceType)
        if (Registrations.TryGetValue(serviceType, out var creator))
            return creator();
        if (!serviceType.IsAbstract)
            return this.CreateInstance(serviceType);
        throw new Exception($"No registration found for service : {serviceType}");
    #endregion
    #region Others
    private static IEnumerable<PropertyInfo> GetInjectableProperties(object obj)
        var type = obj.GetType();
        var properties = InjectableProperties.GetOrAdd(type,
            t =>
                return t.GetProperties(BindingFlags.Instance
                                        | BindingFlags.SetProperty
                                        | BindingFlags.NonPublic
                                        | BindingFlags.Public)
                        .Where(property =>
                                property.GetCustomAttributes(typeof(InjectAttribute), false).Any())
                        .Where(property => property.GetValue(obj, null) == null).ToList();
        return properties;
    private void InternalRegister<TService>(Func<object> creator)
        var key = typeof(TService);
        if (Registrations.ContainsKey(key))
            Registrations[key] = creator;
        else
            Registrations.Add(typeof(TService), creator);
    #endregion
And then I created a base class for all the objects who wants to consume the DI ability of the container
/// <summary>
///     A base object which can automatically inject properties attributed with <see cref="InjectAttribute" /> from the
///     <see cref="IContainer" />
/// </summary>
public abstract class ContainerObject
    // ReSharper disable once UnusedMember.Global
    protected ContainerObject()
        InjectProperties();
    #endregion
    #region Properties
    protected IContainer Container => SimpleContainer.Container;
    #endregion
    #region Others
    protected void InjectProperties()
        Container?.InjectProperties(this);
    #endregion
Of course with the help of InjectAttribute, I can inject service automatically
/// <summary>
///     Inject an object to a property from the <see cref="IContainer" />, the property should always have a setter
/// </summary>
[AttributeUsage(AttributeTargets.Property)]
public class InjectAttribute : Attribute
To better register services to the container, I created some extension methods around IContainer
public static class ContainerExtensions
    #region Others
    public static IContainer Singleton<TService>(this IContainer container, TService instance)
        container.Register(() => instance);
        return container;
    public static IContainer Singleton<TService>(this IContainer container, Func<TService> instanceCreator)
        var lazy = new Lazy<TService>(instanceCreator);
        container.Register(() => lazy.Value);
        return container;
    public static IContainer Singleton<TService, TImpl>(this IContainer container)
        return container.Singleton<TService, TImpl>(() =>
            typeof(TService) == typeof(TImpl) ? container.CreateInstance<TImpl>() : container.GetService<TImpl>());
    public static IContainer Singleton<TService, TImpl>(this IContainer container, Func<TImpl> instanceCreator)
        var lazy = new Lazy<TImpl>(instanceCreator);
        container.Register<TService>(() => lazy.Value);
        return container;
    public static IContainer Singleton<TService1, TService2, TImpl>(this IContainer container)
        where TImpl : TService1, TService2
        return container.Singleton<TService1, TService2, TImpl>(() => typeof(TService1) == implType ||
        typeof(TService2) == implType
    public static IContainer Singleton<TService1, TService2, TImpl>(this IContainer container, Func<TImpl> instanceCreator)
        container.Register<TService1>(() => lazy.Value);
        container.Register<TService2>(() => lazy.Value);
        return container;
    public static IContainer Singleton<TService1, TService2, TService3, TImpl>(this IContainer container)
        where TImpl : TService1, TService2, TService3
        typeof(TService2) == implType ||
        typeof(TService3) == implType
    public static IContainer Singleton<TService1, TService2, TService3, TImpl>(this IContainer container, Func<TImpl> instanceCreator)
        container.Register<TService3>(() => lazy.Value);
        return container;
    public static IContainer Singleton<TService1, TService2, TService3, TService4, TImpl>(this IContainer container)
        where TImpl : TService1, TService2, TService3, TService4
        typeof(TService3) == implType ||
        typeof(TService4) == implType
    public static IContainer Singleton<TService1, TService2, TService3, TService4, TImpl>(this IContainer container, Func<TImpl> instanceCreator)
        container.Register<TService4>(() => lazy.Value);
        return container;
    #endregion
And also an extension around System.IServiceProvider to create service instances
public static class ServiceProviderExtensions
    #region Others
    /// <summary>
    ///     Create the instance of the implementation type, inject all the constructor parameters and inject properties
    /// </summary>
    /// <param name="container">The instance of <see cref="IServiceProvider" /></param>
    /// <param name="implementationType"></param>
    /// <returns></returns>
    public static object CreateInstance(this IServiceProvider container, Type implementationType)
        var ctor = implementationType
                    .GetConstructors(BindingFlags.NonPublic | BindingFlags.Public | BindingFlags.CreateInstance |
                                    BindingFlags.Instance).OrderByDescending(x => x.GetParameters().Length).First();
        var parameterTypes = ctor.GetParameters().Select(p => p.ParameterType);
        var dependencies   = parameterTypes.Select(container.GetService).ToArray();
        var instance = Activator.CreateInstance(implementationType,
            BindingFlags.Instance, null, dependencies, CultureInfo.CurrentCulture);
        return instance;
    public static T CreateInstance<T>(this IServiceProvider container)
        return (T) container.CreateInstance(typeof(T));
    public static T GetService<T>(this IServiceProvider container)
        var service = container.GetService(typeof(T));
        return (T) service;
    /// <summary>
    ///     Inject all the injectable properties
    /// </summary>
    /// <param name="container"></param>
    /// <param name="instance"></param>
    /// <param name="selector"></param>
    internal static void InjectProperties(this IServiceProvider container, object instance, Func<PropertyInfo, bool> selector)
        try
            instance.GetType().GetProperties().Where(selector).ToList()
                            property.SetValue(instance, container.GetService(property.PropertyType), null));
        catch (Exception e)
            Console.WriteLine(e);
            throw;
    #endregion
Now I can write a service and register it on App starts up.
public interface IMyServiceA
  void Method();
public class MyServiceA: IMyServiceA
  void Method()
public class App: ContainerObject, IExternalApplication
  public Result OnShutdown(UIControlledApplication application)
      try
        // do some cleaning
        return Result.Succeeded;
      catch (Exception e)
          return Result.Failed;
  public Result OnStartup(UIControlledApplication application)
      try
        this.Container.Singleton<IMyServiceA, MyServiceA>()
      catch (Exception e)
          MessageBox.Show(e.ToString(), @"Oops!");
In another service I can consume a registered service like this(property injection and constructor injection)
public interface IMyServiceB
  void Method();
// property injection
public class MyServiceB: ContainerObject, IMyServiceB
  [Inject]
  private IMyServiceA ServiceA{ get; set; }
  void Method()
    this.ServiceA.Method()
public interface IMyServiceC
  void Method();
// constructor injection
// MyServiceC is better to be registered to the Container to get created automatically with an instance of IMyServiceA
public class MyServiceC: ContainerObject, IMyServiceC
  public MyServiceC(IMyServiceA serviceA)
    this.ServiceA = serviceA;
  void Method()
It is just a basic design of my DI system with detail reduced. Hope it helps
Message 7 of 9
ricaun
Really cool implementation, maybe a simple library for that could be cool.
The only DI for Revit I know is this framework: https://github.com/engthiago/Onboxframework/
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Message 8 of 9
Kennan.Chen
I created this code years ago for the reason to build the wheels to enhance my technical skills. There are some really awesome open source DI frameworks out there developers can leverage, which makes my DI system look like a toy.😂
Moreover, it is part of my company project which means it requires much refactoring or completely redesign before I can publish it legally. Just like I need to reduce much detail before I can publish it here partially. Revit.Async is such a library I extracted from what I've created in my company project but with a completely new design.
Message 9 of 9
ricaun
Today I created a simple project with your implementation to experiment, kinda add others missing features.
Kinda was able to create a generic RevitCommand.
[Transaction(TransactionMode.Manual)]
public class RevitCommand<T> : IContainerObject, IExternalCommand where T : ICommand
    public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elementSet)
        this.GetService<T>().Execute();
public interface ICommand
    void Execute();
public class CommandA : ICommand
    private readonly UIApplication uiapp;
    public CommandA(UIApplication uiapp)
        this.uiapp = uiapp;
    public void Execute()
        System.Windows.MessageBox.Show($"{this.GetType().Name} - {uiapp}");
And create the button using my ricaun.Revit.UI package.
ribbonPanel.CreatePushButton<RevitCommand<CommandA>>();
DI is fun.
