Regarding almost 10GB installation data diff. between Student and Proffesional vers
Hi !Please, could You explain , what brings than the difference in almost 10 GB of required installation data, between Student and Proffesional version of Revit 2018!?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage, or end-user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us.
I hope this clarifies.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
